mattonthesea
As our electrical system is quite old and has clearly been constructed on an ad-hoc basis I am planning to redo the charging and battery parts. I have already re-wired the switch panel and associated fuses. I have a standard alternator on a Penta 2020. We have 130W of solar PV. The only big power hungry load is the fridge. Otherwise it is standard nav equipment, lights and phones/laptops etc. We also have a Torquedo to charge. I have looked into it and I think I want to go down the LifePo4 route for domestic use. Our pattern is to cruise for three months where we anchor off for up to a week at a time and use the dinghy to go ashore; we then spend a couple of nights in harbour. Obviously, this pattern is subject to external influences. We will be in Northern Europe for the foreseeable but...
Qu 1: at the moment we have 24Ah domestic which is not quite enough when using 70% as minimum discharge limit. If we went for 150 LifePo4 Ah would this add about 50% more useable Ah?
Qu2: If we used a B2B option with Lead Acid Starter Battery then would the alternator regulator be able to cope with the surge if the BMS broke the domestic charging circuit?
Qu3: So far I've looked at Victron and Sterling. The Victron has an galvanic isolating option and is cheaper but the Sterling has a PV input option. (as a further question I have wondered why they don't do an integrated, all-in-one shore power charger, B2B, PV /wind gen input etc. One box
). Sterling batteries come with a BMS whereas Victron don't; however, the Victron BMS is future proofed in that it can be set for multiple batteries. I'm not bothered about bluetooth connections so, apart from this, does anyone have any other issues with either manufacturer/system etc?
Qu4: If we upped to 250W PV on goal posts would this give us enough to keep reasonably topped up? I know this is a piece of string but wondered about others' experiences in this part of Europe.
Qu5: If this all worked would be able to charge the Torquedo battery more efficiently? Our inverter can't cope so we charge at 1% per hour from 12V presently via the switch panel. Is there a way of faster charging from a LifePo4 battery?
Qu6: am I missing anything?
Answers on a postcard!
M
M
