Solvent/cleaner for old diesel gunge
Forest Girl
22 Jan 2010
Taking up the floor of my Fulmar for the first time since purchase, I found a very old diesel spill that, when mopped up, left the surface of the paint/flow coat with a thick sticky nicotine coloured residue. I have tried paraffin and white spirit but to no avail. Any ideas? I thought about caustic soda, cellulose thinners, trichlorethylene but thought I'd check with you guys first.
sarabande
6 May 2005
I suspect you may need a biological cleaner, which is also a lot friendlier to the fishes than trichloroethylene.
Try oiltechnics.com , they have a range of cleverly engineered biodetergents which will eat the gunge up in a night.
VicS
13 Jul 2002
Avoid caustic soda if any surfaces are painted. It is an effective paint stripper.
I would avoid any inflammable solvents and chlorinated solvents like trichloroethylene.
Bilgex may be all that is required to make a reasonable job of cleaning up
dylanwinter
28 Mar 2005
Buckingham
www.keepturningleft.co.uk
boiler suit detergent
or perhaps washing machine powder
go to a big supermarket and buy some detergent that says that is for greasy stains
the slug bilges never smelt so sweet
make a strong water mix
use hot water to help it get under way
sloosh it around
pump it out - hopefully into a bucket
pour it down the loo or into the sewage system which is supposed to be able to cope with it
best not straight into the sea unless actually at sea
if it is really horrible you might need to repeat
Dylan
and next week I will be telling you how to use boot polish in your cutlass gland
Ex-SolentBoy
25 Nov 2006
I will be very interested if you find a solution that works. We have a nice white tray under our engine and due to a small leak, some diesel dripped onto the tray and left a pool about the size of a dinner plate. No gunk, just liquid.
The liquid cleaned up easily, but the flow coat was stained.
I have tried Skippers Choice, Bilgex, washing up liquid, washing stain remover, washing up powder, mixing stuff with hot water, agitation and probably a few other things.
Nothing has made any difference. Of course it is all clean, but the stain remains.
dylanwinter
28 Mar 2005
Buckingham
I agree
there are few things in life more annoying than a dirty drip tray
I feel your pain solent boy
Dylan
Hostage
1 Feb 2011
N>Ireland
When I was looking for a cleaner to remove the sticky mess on an inflatable dingy caused by UV light degradation I discovered on another thread that Fairy Power Spray was the only thing that would remove it.
All the other methods you mention had failed. I tried the Fairy Power Spray and it worked. It is intended for cleaning ovens.
Good luck
Ex-SolentBoy
25 Nov 2006
Dylan
Thanks for the sympathy. Just wanted to save the poor bloke wasting his time with supermarket detergent and hot water.:p
Is now the time to point out that without a centre board your duck punt is going to have an effective tacking angle in excess of 180 degrees?:confused:
Nostrodamus
7 Mar 2011
www.cygnus3.com
Ishould imagine there are a few on here who could lend you a couple of their sterydent tablets. Well they apparently get rid of stains.
Latestarter1
6 Feb 2008
Somerset
When performing repowers always specify cleaning bilges TFR (Traffic Film Remover) available from most commercial vehicle factors, you require the premium TFR used for cleaning oil and grease from commercial vehicle chassis prior to MOT testing, Do not go for budget or envionmental formulations, just the premium stuff in 25 liter tubs which will render tomcats sterile and take the skin off your hands if undiluted. Costs around £25 a tub. Also leaves bilges degreased and ready to paint after rinsing.
Another tip is to use grey commercial workshop floor paint instead of International Damboline bilge paint, my supplier confirms that formulation is identical at a quarter of the cost.
