lumphammer
I have two 80W solar panels connected through a Marlec HRDi regulator. In the evening I switched on my mains charger, which was set to charge at 14.4 volts. I noticed that the HRDi controller was indicating a current on the solar panels even though the controller on/off switch was off. When the charger went to float mode at 13.3v the controller current indicated 0 amps.
Am I right to assume that my solar panels must be missing a diode to prevent reverse current flow?
