stranded
Extending our solar and just want to check a couple of things before I press send on my order, which I need to do before I get down to the boat to check things like fuse sizes.
Currently have 2 x 115 Victron mono panels in parallel through a Victron 75/15 smart controller. Has worked perfectly for years so plan on simply replicating that to double up capacity (very tight space means not depth to fit one of the bigger controllers.
Couple of questions:
20 amp fuse ok for 13.2 amp short circuit current? Does blade or glass matter?
I also want to install switchable breakers between panels and controller - in engine compartment 12v planet has some quality waterproof ones but smallest is 50 amp -would that be OK for 6mm2 wires?
Would it be better to keep the old panels as a pair, or put one new and one older on each circuit?
Thanks as ever.
Thanks as ever.
