rob2
No, two on the centreline are reflections in the super shiny SS.
Rob.
Rob.
View attachment 35126View attachment 35126
Took along time to find one that would fit , first class solar panel. Fitted to an etap 24i
On the backstay, across the 2 legs below the monkey plate, out of the way, secure & beautifully aligned to the sun - 'cos my mooring lies North/South so the panel is always facing due south.
Alignment to the sun is very important and the major consideration. Put a meter onto the output & you will see huge differences between a panel lying horizontal & a panel aligned.
TRADEWINDS : I am intrigued by the notched plate fixed to the emergency Hydrovane tiller arm...? ( Nice nut job btw)
Ah, yes.
I use a Raymarine tillerpilot on the Hydrovane occasionally. I thought the pin point for the ram was going to be further forward so had this fancy plate made. The 'notch' was there to clear the starboard upright pushpit leg (my Hydrovane is offset). In reality the best pin position was further back & so the plate was superfluous.
HTH![]()
30ft yacht, liferaft on garage roof, stack-pack main. Ideas?
It's only used as a back up if I don't want to use the Neco autopilot or am on a short passage & too lazy to get the vane out of the locker.How well does that work?
I've used tillerpilots on servo-pendulum systems, which works very well since all the steering power needed comes from the servo oar, with the tillerpilot simply giving 'instructions': the loadings and power consumption are small. However, a Hydrovane in non-servo, so how does it work?
