Stemar
I'm planning a re-design of Jissel's switch & fuse panel, at least partly to give room for a solar panel controller that charges both engine & domestic batteries via separate outputs. The outputs to each battery will have 5amp fuses, but is there any benefit to fusing the line from the solar panels?
The maximum output of the panels (40w) is well below the capacity of the wire I'll be using, so even a short circuit shouldn't be a problem, which suggests there's no point. Am I missing something?
