AngusMcDoon
I'm looking at solar panels for a new boat delivered later this year. It's a catamaran and there's bags of space on the coachroof that doesn't ever need to be walked on so makes a good space for solar panels. The problem is that this space has a very slight compound curve, and I am assuming that flexible solar panels won't lie flat on a compound curve, but one of the curves really is very small. Here's an above view showing the space where 2 panels in green could be fitted. There's room for 2 175 Watt panels if I use a single panel on each side...
This area has a significant curve lengthways but within the radius of flexible solar panels. It's between the 2 red arrows here...
The crossways curve is only just discernible marked in red here...
and here...
My plan is to attach the panels using 3M VHB tape or 3M Dual Lock, but would that be impossible with these curves, or will the crossway curve be so slight that it will be absorbed by the flexibility of the mounting system?
Alternatives are I could use 6 smaller 50 Watt panels, but that will decrease output (unless I add a 7th on the foredeck) and increase wiring faff and expense...
or use rigid panels and these mounts, but the installation will be heavy and ugly...
Fitting a solar panel to a narrowboat with a curved deck.
and here...
