winfarthing
Well thank you to everyone for your help.
I have opted for two panels which will provide 640W and an Outback Controller. I have the option to fit one extra panel over the bimini which would lift the output to 960W and have chosen the Outback Controller that can cope with three panels.
Hopefully it will all go together over the next couple of weeks and will be interesting to see how it performs.
Interestingly the panel supplier recommended each panel be wired directly to the controller rather than using one wire to supply the output.
I am hoping these panels will provide sufficient power with only limited resort to the other sources - we shall see. I suspect the third panel will prove necessary.
Hi. Just wondering how you went on as I'm looking at a similar project. Which make of panels did you opt for and where did you get them? I'm also trying to source an arch, currently wondering if importing one from Atlantic in the US would be a plan. Any thoughts on a UK supplier would be appreciated.
