Solar panel Suppliers?
Graham376
15 Apr 2018
Seem to be plenty of threads about solar but mainly controllers or flexible panels. I'm looking at replacing our rigid (4 x 43w) Kyocera panels on the arch with 2 x larger output ones. Any recommended suppliers or, ones to avoid? Found rigid mono 150w 1315 x 665 x 35mm which are about the physical size I'm after @ £130 each - is price about right?
Bimble
Its cheaper than Photonic Universe, (£200), so looks OK :)
http://www.nauticayamar.com/solar-panels-light-and-regulators/solar-panel.html
Not too far to go.
Mine are still working ok 3 years later
Just make sure the panel is for 12v system ie 20v max volts if you ar eusing a PWM controller. Many this size are for domestic PV and have a max voltage of 40v which woulkd be oK but needs a MPPT controller. ol'will
Thanks for the replies.
Stu, I had a look at pirate John (Ayamar) a while ago. Didn't have size I want and expensive.
Photonic Universe have good reputation but expensive and Bimble don't have size I want. As Richard says, ebay ones look good value, just unknown quality.
When I was last looking, photonic had regular sales at approx 50% of their usual price. Maybe worth contacting them and asking for a reduced price?
Thanks everyone for the advice, I've decided to go for 2 x Photonicuniverse 160w panels which should fit the existing gantry without mods. https://www.photonicuniverse.com/en...ble-for-camper-caravan-motorhome-or-boat.html
I hadn't realised how much prices/watt had dropped over the years 320w now for £310 (there are cheaper on ebay) whereas my 172w (4 x 43w) Kyocera cost €1,000 10 years ago. Will have to see if my Victron 75/15 will cope with theoretical 17amps from new panels.
The 75/15 can cope with higher amps coming in than 15A but will only output a max 15A. Manual says Max. PV short circuit current 20A so you should be OK.
15A from the controller (presumably at a nominal 12V) might prove rather wasteful when the sun's at its strongest. We have 340W (4 x 85W panels) in the Med which regularly pump out 25A if the batteries can take it.
