skyflyer
Before I installed solar I almost never had to top up the el trolyte levl on my two lead-acid batteries. Charging was done either through engine with an Adverc smart charge controller, or via shore power when available.
Last spring (2018) I innstalled a 100w panel with an Epever Tracer MPPT controller.
I now regularly have to top up the batteries. I’ve got through 2 litres of deionised water already this season.
The Epever manual details a charging regime that should end up in a “float charge” mode when left although it doesn’t specify how long each charge phase lasts prior to the float being applied. This is presumably to prevent boiling off the electrolyte. I tend to leave the boat for three to four weeks on a swinging mooring between visits. The batteries are always nicely charged on my return.
I’m wondering if the problem is a dc/dc charger I fitted between the no 1 battery which is charged directly from the solar MPPT and the no 2 battery which is only directly charged by engine or through shore power.
Could it be that whenever this kicks in, the MPPT cycle starts afresh thus giving too much bulk charge before going to float?
I’m trying to think how I can leave the boat to ensure both batteries benefit but without the boiling off that seems to be happening.
There is one other possibility. Since fitting the solar I have been more “cavalier” about depth of discharge, and although I never go below 50% I am less likely to top up the batteries with an engine run than I might have been before. Could this have an impact?
All ideas gratefully received.
