ddodg
As I am not very electrically minded I would really appreciate if someone could cast a quick eye over my proposed plan for a soar installation.The intention is to use the solar panel only when at anchor or similar to give a smal boast to the batteries.
1) A 100 watt panel
2)A 5metre wandering lead of 6mm2 wire from panel to a bulgin deck plug
3)From bulgin deck plug a fused ( 10 amp) 6mm2 to a Victron 75/15 controller ( seems as though some question whether 6mm2 wire will fit this controller so may have to be 4mm2.) Distance from deck plug to batteries about 2metres
4)From the controller a fused ( 20 amp ) 6mm2 wire to connect to positive main master switch battery connection.Negative to main negative bus bar.
Does this all seem okay. Very open to any positive suggestions to improve.
Many thanks
David
1) A 100 watt panel
Many thanks
David
