stuartwineberg
About to fit 120w rigid solar and want to be able to remove and fold it away so looking at the photonic unit. Don’t really want a deck gland with mc4 or Anderson plugs hanging out and would like to use a deck socket and plug. Short circuit current is 7.4amp open circuit voltage is about 22 and the cable is 4mm single core. Any reason I can’t use a bulgin 2 pin 10amp deck plug. I know I have to cover the panels before unplugging if I use this approach to remove arcing risk.. Not sure if the amperages are ok and whether the 4mm cable would fit the terminals
