Talbot
My boat is a bit of a power hog with refrigeration and freezer as well as other demands. I have 555 watts of solar panel running through an Outback Flex60 controller which is MTTP and provides the appropriate power in very sunny conditions (def not UK at the moment :distress: )
In order to provide the necessary additional power when it is overcast/raining I have been looking at adding a wind generator. I have decided on the generator I want, but the controller is a different matter. There are no MTTP controllers that can really cope with wind, and the only alternative is a PWM controller with a dump load (basically a heater which is going to be really good on a very hot day (sarcasm mode). Furthermore I cannot see how the PWM controller will work with the MTTP one. To my admittedly shallow understanding these two systems would work against each other. I have tried to ask controller manufacturers, but none have actually answered the question.
Does anyone know the answer?
If not, but you are using both systems - how do you use them?
