prv
Took down the headlining on the new boat today to fit the new halyard winches. The deck is cored with foam, the headlining is screwed on with self-tappers through the bottom skin. After taking out the screw, one of the holes released several drops of water.
There's no deck fitting immediately adjacent. About two feet away is a hatch, and when I took off the trim around it I found wetness around one corner, the corner nearest the dripping screw hole. So it looks like the hatch is leaking and the water running down inside the deck. The whole thing isn't saturated, as none of the two dozen or so other headlining holes produced any water.
Obviously I'm going to rebed the hatch, but any ideas what if anything I should do about the deck? Doesn't sound crunchy or delaminated when I bounce on it. Just live with it? Drill some drain holes at the lowest edge? At least it's not going to rot like balsa would have done. Could really do without another project at this point!
