Tranona
Where is your evidence of this - or are you referring to the appallingly built boats from the 1970s and 80s?They were also packed full of voids in the layup which famously blister.
I think your getting confused with information overloadAccording to Fibreglass Boats by Hugo du Plesis, no voids = no Osmosis.
Back in the day commonly boats had voids which blistered - what we call Osmosis. Modern boats less so. I conclude because we've learned how to layup fibre glass without voids.
Material science has improved hugely. I remember seeing grp being wetted out by hand in a shed in Rochford for hunter boats and years later seeing a french boat builder using temperature and climate controlled vacumm bagging for a complete hull. No comparison between the results.It's 10 years since I read it so feel free to correct me.
Yes I'd definitely agree with the moaning bit unfortunately I'm not one of those ELDERLY retirees I just know that older boats were overkill constructed.. .. .A rizzla fag paper is thicker than most modern boats plus there god awful ugly fat arsed things
Yawn. Repetitive, unsubstantiated opinion (prejudice?)All newish are crap compared to pre 2000 .... Nearly as bad as the Leyland Metro tacky plus they've got rear ends larger than Gemma Collins
I think newer boats are well constructed to rather restricted standards. It's not quite true that they are badly designed either but they are designed with a narrow focus.
So, applying a broad brush, they are great in port but can be a liability at sea. "Performance" is often spoken about in this place but what is usually meant is the narrow "sailing speed in flat, inshore water". That's it, bit schoolboy really.
Real all round performance: Sailabilty is another matter - the ability offshore to make good progress with a small crews, in poor conditions, with a minimum of work and attention to the needs of the boat. As the phrase used to have it: "A boat that will look after you"
A lot of modern boats make hard compromises in order to do one or two things well, either:
1) Create as much interior space as possible- which is an excellent marketing tool it appeals to non sailors and is impressive at a boat show.
2) Sail fast - Like the Pogo mentioned, great if you want to race or are particularly interested in sailing fast. Most don't / aren't but, if this is your priority, they are fine boats. In terms of accommodation they are often little better than their slower, older siblings and poor load carriers.
Of course many 1) boats above are alleged to be "fast" but are more often just big. With a 40 ft boat you will overtake an impressive number of older boats, it is as well to notice the LOA of those boats. These bloated designs are actually not nippy even by their own confined standards. If manufacturers know you can have a best seller simply by providing more space it is not surprising you end up with large areas of space surrounded by GRP. I suspect that older design briefs started with sailing needs and worked forward from that.
A lot of what has been described as steady improvement in design are in fact not much more than Sticking Plaster to cover up shortcomings:
Stability problems - make the keel deeper, put a T shape on the end - both a disaster lurking for the average boater
Can't hoist the huge main? - add power winches
Sail handling difficulties - In mast furling
Anchor problems - add a bow sprit ( Hang on I thought the plumb bow was meant to help with mooring costs?)
Handling embarrassments - bow thruster, even better stern thruster
No stowage - put the stuff in a stern "cabin"
Rounding up in 20 kts - twin rudders
Much of this stuff actually hindering speed, whilst adding complication, weight and jeopardy which a cruising boat would be better without.
Always been the case. Our older SO36.2 sails better upright, as do many boats of similar design, but we see a lot of folks with way too much sail up going slower than us heavily reefed. I'm sure it feels exciting, but if it's slower and less comfortable, and more importantly if you're complaining about the boat then I agree that a change in style is needed. Or buy an older boat that suits your sailing style. Older, prettier boats got faster as they heeled so it used to make sense to be less comfortable.you should adapt your sailing style
Modern boats with a chine need some heel. Less than the old IOR influenced boats for sure, but the other point is that when you stick them on the chine like that, they get a lot more resistant to more heel.Always been the case. Our older SO36.2 sails better upright, as do many boats of similar design, but we see a lot of folks with way too much sail up going slower than us heavily reefed. I'm sure it feels exciting, but if it's slower and less comfortable, and more importantly if you're complaining about the boat then I agree that a change in style is needed. Or buy an older boat that suits your sailing style. Older, prettier boats got faster as they heeled so it used to make sense to be less comfortable.
It's only numbers on a page I was told. So I went and spent a load, bloody marvellousCan't take it with you....
My last portly cruiser, a 2014 AWB had a half length chine and sailed stunningly well compared to the previous round hull versions.Modern boats with a chine need some heel. Less than the old IOR influenced boats for sure, but the other point is that when you stick them on the chine like that, they get a lot more resistant to more heel.
So actually a lot more forgiving upwind, as you firstly have a point where each degree of extra heel suddenly requires a lot more force, and also your rudder is now vertical.
As there had been previously. It's a continuous change for the better, with different manufacturers changing at different times. HR, for instance, are just now adopting what BenJenBav were doing 20 years ago.Nowhere near my latest not-so-pocket go faster cruiser but at the end of the noughties there was a major step up in design
I don't think anyone does by choice if they're well informed and want the better option. It's not always about better though as budget and taste come into the picture too. Still a lot of folk around here dreaming of old curvy yachts with manky bilges and single bunks, but the heart wants what the heart wants. I must admit I'm not keen on the newer designs with relatively square sterns (and the loss of the sugar scoop is a tragedy!), which is lucky because I don't have the budget for one anyway!and WTF would want the previous stuff unless there was no choice.
+1.(and the loss of the sugar scoop is a tragedy!)
Ah excellent, it's been at least a week since the last "old vs new" dust up!
And to be fair, your post is considerably more reasonable than some!
Thanks, a nice change from being called names whenever this topic is recycled
BTW. The trap door in the back of that boat is another example of dodgy design ideas. Heavy, vulnerable, expensive and less useful than a sugar scoop but does give more room in the cockpit at a boat show.
What does bug me is the word fast being used as if it is interchangeable with better. Modern or new is often used in the same manner. A lot of people want a docile boat, one that wont be over pressed almost regardless of conditions.
Spoke too soon, let the abuse start:
".....don't think anyone does by choice if they're well informed and want the better option........ Still a lot of folk around here dreaming of old curvy yachts with manky bilges and single bunks"
I can't work out why you cut out the part where I said essentially the same as you just did.".....don't think anyone does by choice if they're well informed and want the better option........ Still a lot of folk around here dreaming of old curvy yachts with manky bilges and single bunks"
I think we all know you think that thoughSee, I haven't ever said that "fast" is interchangeable with "better".
