Magnum
RIP
I'm sure I said in an earlier thread that due to the hassle factor of installation I've given up on the idea of a chain stopper on Magnum. So it's back to a snubber using the Ultra chain grab.
Easiest solution would be to splice to lines onto the chain grab and fix each to the bow cleats via the fairleads. Only problem there is that due to the sharp angle down to the water the lines will be constantly rubbing on the bow section forward of the cleats (Hurricane you are lucky that your P67 won't suffer from this issue).
So how about a Y section snubber like this?
Load direction off the cleats should be OK but the angle of the Y section is too great for a conventional splice. Maybe a simple stainless O ring?
Any other comments?
Any other comments?
