Snapped key
PabloPicasso
12 Feb 2010
After lifting a boat out we noticed one of the red plastic electrical keys had snapped. I forgot to collect the broken stub as we left, but we did measure it at the time and it seemed to be about 10mm diameter. It has a brass spigot also.
I need to order another, is there only one type/size, or do they vary? I don't want to order the wrong part and the websites I've looked at do not give the diameter, only overall height and width.
Can anyone confirm if they are a standard size?
Many thanks
As far as I know...if it’s the one I’m thinking of...there only is one size universally used
These switches vary in quality. The key works against a spring and as the slot wears the connection can fail, the result in the case of bro’s vintage car was arcing and smoke causing a panic bailout. I repaired one with a new half p dropped down the hole. Latest ones I have are much better.
Agree. We had a recent Osculati one fail that caused a lot of mischief.
And as a result we now have three slightly different types - and can assure the OP that sadly the keys are not all compatible. We have three incompatible keys on board, though plan to standardise in future.
I've never really thought about it before but from the descriptions it sounds as though the 'pins' on the key are what is making the connection. Is that right? I think I previously assumed the key was turning a switch mechanism.
No, the red key pushes a connecting bridge down across two others, against a spring, the turn is to engage the pin as a bayonet fitting. If the plastic groove that the key peg is in wears the connection fails.
