pW2
Active Member
I bought a small motor boat some weeks ago with a Vetus/Mitsubishi 3 cylinder motor with 400 hours running. But the motor has not been run for the last 4 years or so. There are a couple of problems if any one can help I`d be grateful. So far I`ve put another 90 hrs on the clock which seems to be accurate. At 2000 rpm she cruises at 5 knts and uses 2 ltrs/hr, though on one 8 hr trip she used 3 ltrs/hr (consumption is measured by dip stick, which is quite accurate, especially as I keep the tank fullish and measure in much the same place in the tank).
The exhaust is smoking quit a lot, sometimes more than others. The injectors have been removed and checked, all good, the tappet clearance has been checked and is OK. The other problem is engine oil which seeps out of the junction between crank case and gearbox, not a lot but after 8 hours running something like half a cup. Presumably the crank case oil seal isn`t working properly and the leak will only get worse.
Is it possible the two problems are related? Just how difficult would it be to replace the oil seal?
Peter
Peter
