mad_boater
I am having problems with the oven door not closing at the top its the type that pulls down to open. The seal is ok in fact the oven has not been used much.I have tried removing the door to see if there is any adjustment with no luck.There is no actual catch to keep it closed just spring loaded hinges.Its a bit dangerous as there is wood above the door that is getting very hot.Any one had the same problem?
