GHA
Well that was interesting. If a little embarrassing.
Couple nights ago heading to bed glanced at battery voltage. Boat's in a boatyard and power goes off at 10pm. WOW!! That's too low, something not right..
"Check battery water" is on sundays weekly repeating check list on todoist, but not been warm & absorption voltage set quite low (T105 batteries) so I've beenbit lax pretty crap and not done it for a while.
First though, check the water. Down near the plates. Oooops!!!!
Topped up and voltage jumped back up a bit when fridge turned off. Might have got away with that....
Yesterday first thing checked the smartguage - 80% , smartshunt - 94%. Something still not right so changed profile to 14.8v & switched off & on mains charger a few time to force it into absorption again til current going in graph was fairly flat then blasted them in equalize at 15.5v for an hour.
This morning graph shows back to how it used to look, 12.64v with 0.85A going out. Smartgauge says 93%, smartshunt says 93.5% .
Phew, might have got away with that one, they're not even a year old yet!
Smartguage was from a sale or demo for hundred quid & I thought it was worth a go the see if comparing "real" state of charge to the smartshunt state of charge could say anything useful about the health of the batts.
Looks like it was worth a punt! Could be well worth considering on a cruising boat.
Smartguages were tested by Rod Collins/compass marine , like many he was skeptical about how a little box with just 2 wires could be produce useful results but was just the opposite after testing.
Balmar Smartgauge Battery Monitoring Unit - Marine How To
SmartGauge Electronics - SmartGauge battery monitor
Good article, also show just what a big deal capacity testing lead acid batteries really is.
Limitations though, smartguage will tell you how full the battery bucket is but not how big, Smartshunt & similar will measure how much power went in/out and how full the bank is but only after you tell it the capacity. Which you don't know.
Both together seem a very useful match
Shame windows laptop gave up , not so easy to get screenshots now on a crappy linux notebook..
Equalizing charge, bubble that electrolyte! Interestingly they didn't heat up much.
Wow - something wrong! Top graph is current in/out.
When the previous elderly t105's were on their last legs the voltage got very volatile like that.
Gold dust in the data!!!!
