smartgauge problem
pessimist
7 May 2003
Exmoor. Boat in Dartmuff.
We have one of these fitted along with a Smartbank, which I think is really just a VSR. Everything works as expected until an engine is run for a while, all is well with solar charging. The Smartgauge then starts flashing E11 which appears to be either a relay or wiring fault. Nothing has been changed on the wiring so I'm assuming a relay problem, but why only when an engine is run? Should say that the problem persists when the engines are shut down. The manual makes mention of suppressing E11, does this suggest that the message is erroneous? Should say that charging appears to be unaffected. My brain hurts.
