Small and light battery charging
qsiv
30 Sep 2002
Channel Islands
I need to find the smallest, lightest aircooled engine which can drive an alternator for onboard charging.
In this search weight (or lack of it is everything) - the objective is to top up 24v batteries on a new race boat. The engine doesnt have to drive the boat, and I would rather not have a through hull fitting, for performance reasons. The exhaust must exit over board, via a long run to the stern. I cant use a nice little portable Honda genny, as portable genny's cant be used below, and all genny's have to be permanently installed. IAE, I would rather not have petrol below decks.
So far the smallest I have found is a Farymann 5 - which weighs about 37Kg, ex alternator. Can anyone do any better?
pvb
UK East Coast
Robin Diesel...
Have you seen the little Robin diesels which are used on small plant hire machines such as water pumps and concrete compactors? They're air-cooled, recoil start, really compact. The smallest one they do is about 5hp, and my guess is that it would weigh in at less than the Farymann.
qsiv
30 Sep 2002
Channel Islands
Re: Robin Diesel...
Thanks - I've asked them for a weight - they dont give it on their web site. It **looks** very similar to the Farymann
tgalea
29 Dec 2001
Malta
Just one comment. I'm undoubtly not into racing so please forgive my ignorance on the subject but i've had farymann for a long time now... and it's a great engine.
Runs like a dream and after 5 years of service still acts as if it was new.
Hope that helps !
Regards
Tyrone.
qsiv
30 Sep 2002
Channel Islands
Thanks!
The new boat will have a high electric demand - but wont have an inboard engine. As the outboard cant be run while racing, I need an alternate charging mechanism. As I'm concentrating on weight reduction elsewhere (carbon rig, PBO rigging, carbon sails), I'm not keen to add any more weight than I have to in order to recharge the batteries.
Is your Farymann an aircooled one? If so is it horrifically noisy, or just plain noisy!?
Jools_of_Top_Cat
16 Dec 2002
on one of our family boats we had an 8hp lambordini recoil start diesel, used about 1 gal per 7hours running. Was a bitch to start, a couple of times it took the rope back around the flywheel.
From what you say I see a problem with cooling down below as even in the open cockpit with a well ventilated engine box it would get quite hot. You might have to fit some pretty hefty fans to keep air running past the fins.
Have you considered a couple a wind gens on the stern, would give plenty of power without noise and prolly much less wieght. Or some hefty solar panels?
<hr width=100% size=1><font color=blue> Julian </font color=blue>
<A target="_blank" HREF=http://www.ukstaffords.com>http://www.ukstaffords.com</A>
qsiv
30 Sep 2002
Channel Islands
Thanks. I dont think solar will be up to the mark in N Europe. Win gens are really surprisingly heavy - and put the weight right at the end of the boat - just where a race boat doesnt want it.
I take your point about cooling - I doubt that the engine would need to run for very long at a time, but I should take acount of it. Mind you in an engine box in a lunch there isnt great airflow - and ont forget the combustion process itself sucks in a fair amount of air.
byron
RIP
UK -Berks
<font color=blue>Jeeze! I seem always be mentioning this firm but I assure you I have absolutely nothing to do with them. Speak to Marlec Marine in Ramsgate, they build gennies and are real experts, they always have dozens of new & recon. engines in stock too. The dude there you need speak to is Mike Roberts.
<hr width=100% size=1>http://www.alexander-advertising.co.uk
qsiv
30 Sep 2002
Channel Islands
Thanks Byron. I hadnt seen you mention them before but I'll get in contac with them now. I'm only after a DC output but otherwise what I'm after would be recognisable as a really small genny!
qsiv
30 Sep 2002
Channel Islands
That looks just perfect - as the boat is being built in California, it's even better.
If I discard the frame we will save even more weight - which will make up for the additional weight of mountings and bearers (not that they will need to be too substantial for such a tiny device.
Brilliant find thanks a lot!
tgalea
29 Dec 2001
Malta
mine is water-cooled but farymann make them air-cooled too. As you said,the farymann is a single cylinder engine and yes it is noisy. To be exact it sounds like a diesel water pump or a diesel agricultural machine.... but as i said it's a great engine, very simple wiring, self-priming (no-bleeding necessary) etc..
hope i've helped.
regards
Tyrone
