Andy Bav
One task I am hoping to undertake at the start of the season is to sluice the black water system to try and "freshen" it up.... The Bav was very basic and easy, a translucent tank behind a removable panel in the shower, fill up from deck pump-out outlet watching the level, add a cleaner / fabric softener, leave and get a pump out.
The V42 is more complicated as for a start the tank is not translucent and we are reliant upon a gauge that I am not overly confident in. Moreover, I am not able to fill up with fresh water from the deck pump-out outlet as after about 15 seconds the pipe fills up, so I am guessing there is a non-return valve somewhere...
The obvious solution is to keep flushing both toilets (Dometic vacuum) with fresh water, which will be fine to introduce the fabric softener etc, but any other suggestions for filling up the tank, with fresh water, more efficiently ?
