The only way to know the condition of your batteries is to measure the voltage - measure it when fully charged and then after discharging for an hour or two with a known load. Previous threads have discussed at great length the precisely correct way to accurately test, but the short version is to fully charge the battery and switch off the charger - after 20 or 30 minutes (??) you should see about 12.7v; turn the radio on and play music for a couple of hours and you should see 12.4v or above.
As said, 4 hours may not be long enough to fully charge them - a smart charger is better as it maintains a float charge once the bulk and absorption stages have been completed. Looks like this typically takes 10+ hours.
Topped up my 6v T105s ..
I interpreted the "s" in "T105s" to mean plural - two wired in series for 12v total.Testing and monitoring, also the load, is important. However your stated voltages won't really work for the OP as he stated it is a 6 volt battery.
I think that's much more likely than someone running a 6v house bank.
But some mechanism is needed to deposit a dense corrosion product upwards onto the caps. Boiling or at the least overcharging would be very likely.Lead dioxide, along with some impurities from the water, breakdown products from seals or the case, or perhaps some trace of grease from when it was manufactured. Common and harmless, so long as it is minor. Might be related to over charging, but possibly not.
Overall though, is it worth bothering?
The ultimate problem may not lie with the battery but with the charging system, replacement without further investigation may be expensiveSome battery companies will test one's batteries for free. Overall though, is it worth bothering? Lack of battery power can result in rescue or loss of boat so buy a new one.
