sleipner side power problem
Festus
2 Apr 2015
the side power in my boat is made bij a sleipner motor as SE 40/125S with a panel model 8960G
the problem is:
normally this will be in working mode for about 6 minutes.
now it only works for 6 seconds and then it automatically turns off.
untill now it seems this is caused by a thermal switch.
we cannot find the problem
does has somebody the answer ?
the problem is:
Most likely to be the switch, useless things, unfortunately when using them on production boats (about 20 per year) the failure rate was very high and was always changing them, some the customer insisted I fitted just the joystick and done away with the electronics part of it, easily done and never a problem again.
the problem is:
ring mike at osmotech.
he will know the answer
he will have the parts to fix it
he will give you all the advice you need to fit it yourself, or he will fit it for you
the price will be fair and reasonable
no connection etc. just my experience of using them
