Skin fittings: when do you replace them?
  • Every 2 years (regardless of conditions)
    Votes: 0 0.0%
  • Total voters
    46
Why did they need a backing plate?
They probably didn't, Just the valve screws directly onto the fitting right up against the inner surface, and I wanted to spread the load over a wider area of the hull - not a concern about the valve's strength.
The skin fitting is supplied over length with instructions to cut it to the correct length to suit the insertion distance into the valve.
