damo
Apropos the skin fittings debate below, what thoughts do folks have about the following situation?
I have a centre cockpit boat with 2 x 1.25" drains which cross over to seacocks. I have just replaced the gate valves with ball valves, and while the engine was out I have glassed in pads to take two more drain seacocks. The thinking behind this is that offshore regs deem the current setup inadequate for rapid draining, so if I ever manage to do an OSTAR I would either have to change to BIG through hulls (no room round the engine) or fit 2 more, hence the pads.
Even if I don't do an offshore race, present design thinking is that the drains are too small for the cockpit volume. I have already got rid of 3 other redundant skin fittings (log, galley seawater, heads sink drain).
So which is the greater risk - 2 more holes in the boat, or a (deep) cockpit full of water for twice as long?
