capricorn
Hi,
I'm adding a domestic battery bank to my boat this winter and as a result of moving the batteries and isolator swich around need to replace/add new battery cable.
Could someone advise on the correct size battery cable to use ?
I have a Yamnar 2GM20 with the standard 70a alternator (as far as I know). The new battery setup will have an 85ah starter battery and (probably) 2 x 105ah domestic bank.
Due to the less than ideal location of the domestic bank some of the cable runs will be quite long - maybe 8 metres round trip from battery to starter. I was thinking of using 35 sqmm flexible multistrand cable which is rated for 220 amps, does this sound about right ?
I know how to calculate the volts drop for a given cable/current but don't know how many amps the starter motor draws, can someone give me a ball park figure ?
