Size of starter motor bolt for Perkins 4108
pcatterall
2 Aug 2004
One of the bolts holding my starter motor on is missing! Its the one next to the engine. I meant to find the size before I left the boat ( In the Med ) but forgot ( or did it but have forgotten where I recorded it!!)
At a guess it will be something like 7/16" unf. and max 2" long.
Can anyone help confirm the size or suggest the range of sizes I should take with me when we set off again this spring.
Most obliged
My parts book says 3/8ths NF x 1. 3/4, BUT that is for an automotive gearbox so it depends on your gearbox flange thickness.
So if you take 1; 3/4 & 2 ; 1/4 you should cover it .
Most obliged
Peter
I think I have some NF bolts in the garage off my old BSA, I will look tomoz if you want them
Stu
Thanks guys. Stu.....I will not put you to the bother of finding and sending stuff from the 'Bits Stuck Anywhere' but very many thanks for the offer.
I still have a good old fashioned hardware/engineering supply dealer who I'm sure will find the parts for me.
I will go for a range as suggested by essexboy.
