Size of French freshwater hose tap fitting
Most do fit but it is best to carry a selection of adapters anyway and we have Hozelock adapters which are cheap enough in Homebase. Also worth carrying is a short (3 or 4ft) length of hose with a connector fitted for the few French marinas that have the tap fitted into a recess in the pontoon rather than fitted in a stand box or even the electrics supply box, this saves unwinding the whole hose for a bucket of freshwater.
British fittings tend to work over most of the continent, but there's no reliable unique standard. For more flexibility, carry a range of sizes, including a few jubilee clips and some short lengths of different internal diameter flexible pipe.
For ultimate flexibility, one of those lengths will be made up of bicycle inner tube, with a back up roll of duct tape to stop it balooning up too much . . .
Most screwed pipe fittings in France are called some different but they seem to correspond with BSP. Sometimes in the DIY stores they have a 'brass' plate with the various threads along with the imperial and metric size.
Whilst there are lots of metric threads for engineering purposes they (Europeans) never got round to a pipe thread.
They all adopted British BSP and in my experience - France and Germany they call it just that - BSP!
Several people (well more than one) have told me that BSP is in fact a metric thread. Goggling "BSP threads" show dimensions in inches that don't readily translate to mm. So can someone enlighten me??
As far as I know (British Standard Pipe) BSP threads are named according to the internal diameter of the iron pipe they were made for. So the thread on the outside of a 1/2" internal diameter iron pipe is 1/2" bsp. It may one day be usefull to know that most 15mm compression fittings for copper tube have 1/2 bsp threads, but 22mm do not have 3/4!
