GeorgeTina
I am considering changing from slab reefing (at the mast) to single line reefing from the cockpit. On my Beneteau First 305 the Mainsail is attached to the mast by slides which are fed though a "gate" which is closed when all the slides are in place. The gate is some 10inches above the rams hook. On reefing it is neccessary to open the gate to allow the bottom slides out to allow the sail to be lowered enough to hook over the rams hook. I can, of course, remove the gate but I then have a mast track with a hole large enough for a slide to come out when lowering the sail or when shaking out a reef. Anybody sorted out a similar problem ?
Thank You and Merry Christmas to all
