Daydream believer
One benefit of the system that I have shown is that it would be easier to repair at sea. i damaged a reef line when it caught on a sharp edge of the mast aligner & ripped the outer covering off. I had to replace it. To make matters worse I accidentally pulled it out of the boom.
I taped a thin line to the other reef line & pulled it through. Then using a wire coat hanger & swapped it to the required blocks each end of the boom. Then i pulled the new line through. It was a faff & involved some rude language but I did not have to remove any boom fittings or cars. That would have involved drilling out pop rivets etc & re rivetting. A process that one does not really want on the end of the boom, as it wears on the holes.
