zyx
New Member
Hopfully someone may be able to assist here, I have fitted to my boat a Silva log and depth sounder that does not work, as you may know Silva no longer make these units, I have however managed to obtain a new tranducer and a new Nexus depth box connection, I do not use the log function.
The instrument seems to function in the DEMO mode but will not record any depth reading just the three dashes to show no reading, I suspect that at some time the wiring may have been altered, I have a diagram for the rear of the instrument that shows the correct position of the screen/white /yellow and green wires also the 12 volt supply connection, however I have no diagaram for the correct positions of the wires entering the depth box connection.
At the moment the wires enter the four pin plug in connector in the following order, looking at the top of the plug ie the clip side I have from the left screen/white/yellow/green...... is this right?
Any ideas, suggestions most apreciated.
John.
John.
