Quester
Like many others I have a Silva S15 DSC VHF with a defunct memory backup battery. Symptoms: loses squelch, volume, MMSI number and date/time settings. The battery is a Panasonic CR2016 soldered to the PCB.
The CR battery designation means a primary battery not a re-chargable but when I check voltage whilst it's still soldered to the PCB it starts at a discharged 0.1 V and rises steadily over a period of time (currently 1.36 V after the VHF switched on for a couple of hours) so is obviously being charged.
Does this mean that, not only is it a duff battery, but that a blocking diode is failing to stop a spurious charge getting to the battery or that Silva did not design the circuit correctly?
Forum member Oilyrag says he's replaced his with a Maxell ML2016 T6 which is a 25 mAh re-chargable but 25 mAh seems very low for long term (power off) backup.
Can anyone throw any knowlegable light on this conundrum?
