jtwebb
I have a Silva S12 radio which is causing me various problems and I wonder if anyone else has the same experience. The problems are:
The loudspeaker quality is very poor
I am told the transmission quality is extremely poor/unreadable in some cases. Experiment shows it can only make 5 or 6 transmissions before quality goes.
The is no battery low indicator so one does not know when it needs a charge so one has to keep premptively charging.
The ergonomics are bad but that is not a dangerous point.
I was told by one Marina recently that they conisder the unit dangerous as I do not know of my failure to contact them properly. At the time I could see them, had charged the radio a few days before, made 5 transmissions and turned it off in between. Indeed, one has to make sure it is turned off as if the battery goes low then the turn off button fails to work and the radio makes revolting noise until it is totally flat!
I ma told it will have to go back to be bench tested which will presumably be under ideal conditions, full volts etc. I wish to use it in real life, even in a life raft if necessary.
Any comments please?
<hr width=100% size=1>J Webb
