neil1967
I want to 'T' into a 38mm hose used as a cockpit drain (one of two). The new hose will be of substantially smaller diameter (13mm). The simplest solution would appear to be to use a silicon/polyester hose which can be bought relatively cheaply as a reducing 'T'. Would this be suitable for use below the waterline - the cockpit drain seacock would be left open most of the time we were aboard, but would be closed during any period of extended absence (the other cockpit drain would cope with rain water). I would attach the T directly to the seacock and then the existing end of the cockpit drain hose to the T with a joining piece. Thoughts?
Neil
Neil
