Sikaflex
I once saw a post about a guy who used sikaflex 291 as well as bolts to mount an aux o/b bracket , a year or so later when he wanted to move it to the other side of the boat , quite a bit of the gel coat came away with it , made a right mess , so 291 would certainly do the job , so long as you didn't want to move it at a later date ,,,,,,,,:)
which Sikaflex should i use to stick me solar panels to the coach roof?:confused:
As said Sikaflex 291 but you'll not be likely to remove it again.
My first solar panel was bolted down and also sealed to the deck with a silicone sealant.
I could not even release it from the Silicone! When it failed and had to be removed I broke it into many pieces in the process.
The new one is only bolted down
For bedding/sealing my new Gebo hatch, I've been told by Seateach to use a polysulphide sealant as it is then removeable (should the need arise) at a later date. Toolstation do one at less than a fiver a tube.
I would have thought that assuming you're using screws and/or a frame to actually position the panels, the same principles would apply?
No Frame or screws.Just a semi-flexible panel direct on the roof.
