AngusMcDoon
Yes, AFAIK, it's cured by water vapour in the air. Cold air contains less.
I have heard that the curing reaction pretty much ceases at freezer temperatures, but I'm not a chemist.
I've heard that there's one case where it doesn't work, and that's when a tube owner's SWMBO finds something sticky nestling amongst the peas and vol-au-vent cases and lobs it back out into the shed. However, as I don't have a SWMBO, I have never tested this scenario.![]()
Just make sure SWMBO cannot find them under the frozen sprouts...If you put part used tubes in a freezer shortly after using them and keep them there the nozzle doesn't bung up and they last for ever.
When I was working and could get hold of them I used to fit a rubber policeman on cartridges not supplied with a cap.
What sort of job involves regularly getting hold of rubber policemen?![]()
But does your nozzle bung up ?!I've heard that there's one case where it doesn't work, and that's when a tube owner's SWMBO finds something sticky nestling amongst the peas and vol-au-vent cases and lobs it back out into the shed. However, as I don't have a SWMBO, I have never tested this scenario.![]()
Your 'Glad wrap' is our Clingfilm. A few layers of that is OK. 'thick polythene' is something a bit more substantial from a polythene bag eg a supermarket carrier bag. I use whatever is to hand. Cooking foil is just as effective.When people say "thick polythene" I am confused. In Australia we have a kitchen product called "glad wrap" which we stretch over (say) a bowl of left-overs or wrap sandwiches for lunch. I empty the tip with a screw-driver, put several layers of "glad wrap" over the tube and screw the tip back on. I even showed a tradesman how to do that but I suppose they use their tubes constantly so it doesn't get a chance to harden.
