Sikaflex and rain?
Roach1948
27 Apr 2006
www.dallimoredesigns.nl
Can I get away with attaching my rubbing strakes in the pouring rain? Will the Sikaflex still work? My yacht moves to the boatyard Tues AM and I can't transport the rubbing strakes without them being attached as they will simply snap or fail at the scarfs...so hence my idea of attempting to attach them in the rain.
Peterduck
10 Apr 2002
Melbourne, Australia
I wouldn't expect Sikaflex to attach to a wet surface. You must be using some form of metal fastening to hold them in place, even if you are hoping for Sikaflex to hold them in the long term. Why not just dry screw them in place, and apply the Sikaflex when the weather is a bit more amenable?
Peter.
Captain Coochie
19 Apr 2003
London
No , your joints need to be dry and clean for any glue to make a good bond . Can you not throw a tarp over her to get the job done ?
PS i have a half penny and a trepney bit from 1948 if you want to step your mast on them ?
oldharry
30 May 2001
Sikaflex wont stick to a damp or wet surface. Unless its your hands - face, arms, legs etc when it sticks like /forums/images/graemlins/laugh.gif however wet you are!
Been there, got the teeshirt, still finding patches of sikaflex at bathtime! And had to go back with a fresh tube on a dry day!
Roach1948
27 Apr 2006
Peter, good idea. Will attach them without bedding down just yet, although it looks like it is drying up later today.... might give it a go then. Dont really feel like screwing on, taking off and rescrewing with bedding (and missing all the holes as the bedding compound is hiding them!)
Roach1948
27 Apr 2006
I need a get a tent rigged with sides in this cross wind. The gunwales still get sprayed. I'll wait till a dry spell (maybe later tonight) and dry the sides off with a manky old towel.
PS. Jason, that is a very kind offer and would love to step her mast on one - specially as it is from a fellow forumite with a similar Seedhouse project!
Bajansailor
27 Dec 2004
Marine Surveyor in Barbados
Could you perhaps fasten them with screws now, while using packing spacers to ensure a uniform gap of a few mm between the rubbing strakes and the hull?
When you are ready to 'send the screws home' all the way, remove the spacers, run the Sikaflex liberally along the gap created between strake and hull, and then tighten up the screws. I have put a gunwhale on a dinghy this way.
Roach1948
27 Apr 2006
Tried your suggestion last night and I am back to square one now as the splines failed (obvioulsy I am useless at splines)! So now they can fit in the back of the car!
pyrojames
9 Aug 2002
Cambridge
transat2013.blogspot.co.uk
Good luck. It's weekends like the one gone that make me appreciate the farmers grain store.
Launching on Friday, only sheet winches to finish outside, then there is the cabin.....
PyroJames
Peterduck
10 Apr 2002
I'm puzzled by your reference to "splines". It sounds like you mean "scarphs", the shallow tapered joint between lengths of timber. If this is the case, you'll need some form of backing to keep everything tightly together. Have you allowed the adhesive enough time to develop its strength? It is very frustrating to make a definite time to launch when there is so much still to do. I assume that it is necessary to do it so that you can book a crane or similar launching method.
Peter.
Peter.
