C
catalac08
Guest
Hi
Trying to bed down a shower tray with underside of exp PU foam/ or similar high density foam onto a wooden platform faced with formica type facing. Not able to use solvent based adhesive as this will melt the PU foam and non-solvent based adhesive (grab Type) remain soft as there is not enough absorbency in either of the contact materials. With hindsite I should have used plain timber which would have absorbed sufficiently to harden the non solvent based goo but having constructed a solid platform I am reluctant to take it apart and re-route the shower drain access.
Does Sikaflex dissolve PU foam and is this an option-yes i realise it would be there for ever!
