Side Power Bow Thruster
Caladh
25 Oct 2009
Out there again and no longer dreaming
Control panel push switch for the R/h thrusting intermittent entry works. L/h is fine. When it doesn't work I g
Just get a click from the control panel. So I want to confirm that the micro switch for the r/h is iffy. I've had the panel out but other than the connections which look good and I've re-made, there appears nothing to service.
It's a sealed unit, so you can't do much with it. You could try jumping the connections in the loom to see whether the right hand operation is still intermittent - that would suggest a problem with the main solenoid. The wiring connections are shown in the manual.
