abraxus
Most of the time my shower waste pump works ok, but occasionally it makes all the right noises but doesn't pump anything out.
On those occasions, if I go outside, take a hose, and squirt some water up the outlet, then it gets going again, and once it does it's fine. However, each shower is a lottery, never knowing whether the pump will start pumping, or whether I have to nip out and fire the hose at it to get it going.
So, can anyone throw some suggestions at me as to what the problem might be and how I can go about fixing it. If it helps it's a Flojet diaphragm pump.
Many thanks.
Many thanks.
