KellysEye
>Having the shell plating only spot welded to the frames is unusual, because it means that the shell plating is likely to be inadequately supported. There are also plenty of properly designed steel boats that have stringers.
We haven't seen any lack of support of the frames they are hard against hull. On the subject of stringers I accept that you can have holes in them but as I said they are not needed for structural support unless the frames are widely spaced, which is not a good way to build a steel boat because the stringers add weight.
Were the steel boats you've seen with stringers built by a professional yard or home built? If professional I would be interested to know the names of them.
Our boat was built by Tak Jachbouw to a De Vries Lentsch design. Tak's main business is ocean going tugs so she is built to commercial standards including steel firewalls in the engine room.
