steve yates
My longbow mizzen mast has two shrouds each side, one pair slightly, and I mean slightly forward of the mast.
I've tightened that up but the mast rakes aft about 15degrees. I haven't tightened the other pair very much as I don't want to rake it back any further.
It does have a triatic stay to the mainmast, which has to be attached yet, but everything I have read on these ( not much) suggests that should not be over tight. Is it the triatic job to straighten the mast? Or the the forward of the shroud pairs? Or is a rake aft normal? The main,sat is not raked. ( boat is for cruising, not racing)
The main reason I ask is I need to go up that mizzen to rig the triatic
and I don't want the bloody thing coming down on me.( Just in case I will rig a warp from it to the mainmast while I go up.)
On the forestay, how tight should I be able to get that? I am assuming the forestaytension is controlled by the backstays? (Mines are split) Its a roller furling set up.
The Genoa halyard has jumped off the sheave at the masthead, so I will be going up there too to sort that out, anything else I should look at/do/add to improve a furling Genoa system while I'm up there? Will spray the sheaves with silicone spray, but that's all I can think of.
Thx.
Thx.
