Hello Peter
All depends on whats going to be running on the boat when using shore power ie: how much current draw from the boat and how long your shore power lead needs to be.
In most instances, unless your planning to run lots of heavy consumers, 2.5mm should be OK.
What are you planning to run?
Simon
<hr width=100% size=1>I'v got 2 ears.2 eyes and 1 mouth....if only i could use them in that proportion!
b/charger-500w,...lights-150w,...tubeheater-700w,....dehumidifier-500w,...kettle 2000w.
Total 3450watts
3450/220=15.6amps (neglecting power factor)
Your pretty much on the safe limit of what 2.5mm cable will safely take (as long as its lenght is under 20 meters)
As long as you can avoid making a cup of tea while checking the battery charger's operation in the midle of a very cold humid winters night....then you should be ok!
Hope this helps.
Simon
