joejo
Why is that? Do some treat it like a static caravan park?
We ventured our last weekend
MDL own and are responsible for the maintenance of the private artificial channel or cut. The EA are responsible for the channel from below the lock to MDL’s cut.
Both are subject to an agreement for each party to maintain their bit to a depth of 8 feet.
Most would accept that maintenance at those depths is no longer critical for safe navigation but the shoaling on the opposite side of the channel to the clubhouse does substantially reduce the width of the available channel in an area of considerable two way congestion, at least in summer months.
This is exacerbated by a fallen tree in the channel partly across the mouth of the Abbey River increasing both the difficulties in navigation and the flood risk.
Boatone is right in advising that sufficient depth is available if you stay well to the clubhouse side but I would advise caution if any sort of stream is running to avoid being swept onto moored boats outside either the clubhouse or visitor pontoon if staying too close.
MDL should remove the tree and the EA should dredge at least this small part of the channel.
Not really a matter for the TMBA unless boats are running aground when they keep to the marked channel. We did get involved when one of the buoys went AWOL to make sure it was put back after the floods.Is this something the TMBA could push on our behalf, as its only a very small area that needs dredging, not the whole channel ?
not that I am aware of.Ok, one last question, does anyone know if there is a Penton Hook Marina Users Group ?
