jon_bailey
I am trying to faultfind my VHF radio because the handset on the flybridge does not work at all. I am not sure whether it is the handset or the connectors/cable. Unfortunately the connector for the bridge handset is completely different to the handset in the cabin so cannot simply swap them over.
Question is, does anyone have a Shipmate RS8100 with a flybridge handset plugged in through a 10 pin circular connector (not sure if this is a standard fit or not). At least I could then check the handset and eliminate that. Alternative is to breakout the connector(s) but this is not going to be simple.
Boat is based on the Itchen.
