JeffBoath
Following on from my previuos post related to correctly tighening up a prop on a shaft and lining up the hole in the drilled nut with the drilling in the shaft, I now need to locate a 1mm thick stainless steel or phosph
er bronze shim (washer) the internal diameter is 22mm. I've been the my local chandlers who thought it was a bit of a head scratcher. Any thoughts on where I might get one?
Thanks.
Thanks.
