Laundryman
Nearly finished my nmea 2000 backbone. Autopilot, Actisense and radio all have shield wires. Where is it best to connect them to please, or do I need em? Everything seems to work without ! Thanks. Alan
You probably need an expert's advice like WilliamH et al. If they are shield wires then surely they must be connected to a ground plate or maybe the motor (which would ground through the propeller) Now where are all the experts?
Shields in data cables should normally be connected to signal ground or chassis of the equipment, close to the connector.
It is sometimes best to only connect them at one end, generally the receive end.
Things will often work fine with the shields unconnected, but it gives better immumunity to interference and less chance of interfering with anything else.
That's general for any data wiring, not specific to NMEA 2000.
