PabloPicasso
Will sheet to tiller self steering work on a fin keel yacht? Anyone tried it?
I am setting this up next summer, although I am a bilge keel I suspect a fin keel should work better.
I think the Youtube setup is over complicated, but have found this useful.
Thanks DI do find myself experimenting with self steering on long passages
usually some-time between the second coffee and just before making the bacon sandwhich
it seems to me that you do have to be prepared to back off your fastest speed in the persuit of balance
Katie L will self steer with a locked off tiller for hours and through quite rough water on everything from a fetch to a broad reach
a bit of backwinding of the main by an slightly over-tightened genoa can help
when the wind is at a four or five then I drop the big main and gunter and use a loose footed sail rescued from my son's old topper
then she balances perfectly and just chunks along forever - you can steer by rolling in or out a bit more genoa and also by raising and lowering the plate
could I sleep? No... but the occasional cockpit doze for usre
D
